Technical Forum
Which nodes will be selected
if i have two nodes, one which donate as "X" is directly connected at f5 and another which donates as "Y"i have static route to reach them, and i have these two nodes at pool, and i use Priority Group Activation less than 1 , i make priority for "Y" is 10 and for "X" as 5, now when request is got to that pool which node will be selected.
X ==== Directly connected with priority 5
Y ==== Static route to reach with priority 10
1 REPLY 1
Samir_Kumar_Jha
Legacy Employee
Legacy Employee
If Priority group activation is set then f5 Big-IP will use available members with highest priority number first.
So traffic will go to Y member.
