Daniel_Vu_10371
Mar 19, 2007Nimbostratus
What wrong with this irule
Could someone tell me what wrong with code below?
if { NODE:[LB::server]) eq "172.16.1.15"} {
TTP::redirect "http://www.test.com/signon.htm"
I got the error:
01070151:3: Rule [new_rule] error:
line 5: [parse error: PARSE syntax 232 {syntax error in expression " NODE:[LB::server]) eq "172.16.1.15"": variable references require preceding $}] [{ NODE:[LB::server]) eq "172.16.1.15"}]
Thanks,
