What solution of F5 should i select for a Proxy gateway.
Viet_Vo
Hi Team,
I want to use F5 as a proxy gateway. My local PC dont have internet access and i want to point the browser proxy address to F5 External Self-IP. Therefore, my local computer can access the internet. My question is:
  1. What F5 solution should i use ? LTM then configure it as a Web access proxy. If Yes, Please give me an advice with it. OR i use SWG module ?
  2. Is it possible if i use only SWG without APM module ? I dont need to filter or manage the access. Just simply give my Local computer internet access.
  3. Is there any live support with F5 team? Chat or Call center ?
1 REPLY 1
Samir
Nacreous
Nacreous
Suggest you to have live demo with F5 sells team. For more information​ click hear.
https://www.f5.com/products/get-f5
