19-Oct-2021 06:16
What is the difference between date and clock command. What would cause the two to me different and how do I sync them up?
ltmA# clock
Tue 19 Oct 2021 12:13:53 AM UTC -0.001128 seconds
ltmA# date
Tue Oct 19 13:04:43 UTC 2021
# tmsh list /sys ntp servers
sys ntp {
servers { ntp.local.domain }
remote refid st t when poll reach delay offset jitter
*10.211.252.9 138.236.128.36 3 u 774 1024 1 2.682 -0.565 0.530
24-Oct-2021 22:29
clock:- which is a software clock used when the system is running that stores time according to the local time zone that you configure when you initially set up the system. clock capture the time from network time protocol (NTP) server.
date:- it is used to display the system date and time. It doens't show all details.
