Technical Forum
WebSocket Connection is not being established to the node on 11.5.4 Version.
Suresh_Sanga_27
WebSocket connection is not being established with F5 VIP on 11.5.4 Version.
We have configured VIP to allow the socket connection. I see the traffic coming to F5 and then redirecting to node, however the node is not receiving the initial http connection call. When I bypass the VIP and hit the node directly I can see the traffic. Tried with protocol type as Standard and also the Performance Layer 4 with FastL4 profile. I am not using the iRule to disable http traffic since we are on the latest version of F5 version. Any suggestions are most welcome to make it work.
1 REPLY 1
Poseidon1974
Cirrus
Cirrus
Hi ,
Any update, i have same issue ,
