Technical Forum
websocket configuration
Poseidon1974
Altocumulus
Altocumulus
Hi
which would be the best practices to configure a websocket application, I mean type of VS, profile etc.
Thanks,
2 REPLIES 2
mihaic
MVP
MVP
There are websocket profiles. So you might use the default one or create a new one.
here you have more info:
https://techdocs.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-implementations-13-1-0/29.h...
https://my.f5.com/manage/s/article/K14754
Poseidon1974
Altocumulus
Altocumulus
Solved, wtih ssl offloading.
