we want to stop the manual EDGE client update for clients
rajeshramhit
we want to stop the manual EDGE client update for clients where the edge client package already has component update set as yes.
seems not possible unless a new package installed
"The Component Update setting is part of the BIG-IP Edge Client install package. After installing the BIG-IP Edge Client, this setting cannot be modified on the client device, unless the BIG-IP Edge Client is re-installed on the client device using an installation package that contains the setting. When you change this setting on the BIG-IP APM server, the BIG-IP Edge Client does not automatically detect and use the new setting."
https://support.f5.com/csp/article/K15302
2 REPLIES 2
rajeshramhit
Any help appreciated
Hello, Unfortunately I do not believe there is a way around this setting. You will need to reinstall the client with this setting off.
