03-Aug-2018 02:18
Hi,Could someone guide me what are the factors to be considered while sizing a WAF(Physical & Virtual Editions) to a customer.
Regards Sriram
Solved! Go to Solution.
03-Aug-2018 06:23
Below datasheet of F5 appliances.
https://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf
You should ask your customer for:
And of course the required physical ports and speed. Copper? Fiber? 1GB or 10GB.
Regards, Martijn.
03-Aug-2018 06:23
Regards, Martijn.
14-Aug-2018 03:34
Hi Martin, Thanks for the information.
03-Aug-2018 06:23
Regards, Martijn.
14-Aug-2018 03:34
01-Jul-2020 00:36
What about object size?
26-May-2022 19:53
Hello,
This is only datasheet for LTM BIG-IP performance, not use for WAF.
Thoughput via WAF different LTM on BIG-IP platform.
Thanks,
