Nilesh_Dubey_36's avatar
Nilesh_Dubey_36
Jan 28, 2019
VLAN communication in F5
Hi Friends,
Is it necessary to keep VIP and pool member in same VLAN or we can put them in different VLAN.
Thanks,
  • Just add necessary vlans to VS(VIP). There is no vlan option for pool member.
  • wlopez's avatar
    wlopez
    Best practice for most use cases is for the virtual server IP address to be on the external vlan (the one facing the rest of the network) and the pool members on the internal vlan (behind the F5), using the F5's floating IP address on the internal vlan as the poll members' default gateway.
    You can also do one-arm where everything is on the same vlan, but you would need to get into using SNATs on the virtual servers.
