01-Jun-2023 02:28
Hello All,
We have added our Website to F5 in Virtual Server and status is coming as Enabled. When we access the webserver, we are unable to get any Traffic logs in F5 logs and also in Remote Logging server.
We have also added Request logging profile to our Virtual server.
Could you plese let us know the configurations to change to get Website traffic logs? Your help will be of great assist to us.
Muthu
01-Jun-2023 03:15
Hi @Muthu_435 ,
From your query , I see you need to log all traffic , which is a bad approach no need for that.
You need to log all traffic in troubleshooting by Taking Packet captures / or assigning irule or Local traffic policy to do that.
It's applicable yes , but in heavy virtual servers / Websites , you will fill your Log files with un needed info for normal users.
But you still can do it.
create simple LTM policy and Log ( Client address , Virtual server Local address ) also you can Log almost any information in each request , but this a bad approach and recommended to keep your logfiles for errors / or alarms only.
Code
when CLIENT_ACCEPTED {
set client "[IP::client_addr]:[TCP::client_port]"
set vip "[IP::local_addr]:[TCP::local_port]"
set snat "unknown"
set node "unknown"
when SERVER_CONNECTED {
set snat "[IP::local_addr]:[TCP::local_port]"
set node "[IP::server_addr]:[TCP::server_port]"
when CLIENT_CLOSED {
log connection info
log local0.info "Client $client -> VIP: $vip -> SNAT: $snat -> Node: $node"
This is a sample irule for that , I haven't test it but it's logic looks fine.
but as I said this is a bad approch , use it only for debugging or troubleshooting and disable it in normal scenarios / cases.
I hope this helps you 🙂
01-Jun-2023 04:40
Hello @Mohamed_Ahmed_Kansoh
Thanks for your quick response. We are trying it new and Just wanted to confirm which IP address which should be added in Client,server and VIP?
We have created a pool with our Website IP and created a Virtual server. Also created a LTM policy and action is set as Log at request time. Please find the attach screenshot for reference.
Muthu Mahadevan
01-Jun-2023 04:52 - edited 01-Jun-2023 04:55
Hi @Muthu_435 ,
you're missing something :
you have to add the below tcl Script in the message box :
tcl:[IP::client_addr]
To Log the Client Ip address Accorfing to this Article :
https://my.f5.com/manage/s/article/K06107145#:~:text=You%20can%20log%20the%20client's,and%20click%20....
> Also you can creat several actions of logs to log virtual server and SNAT IP and the selected pool member address or server address and port..
> Also I will show you a Devcentral Article , I replied back with the some of available scripts can be used in logging by LTM policies , you can check it in this LINK :
https://community.f5.com/t5/technical-forum/local-traffic-policy-for-creating-logging-profile/td-p/3...
> Also you can use the irule that I sent to test that.
But please don't forget to remove irules/ LTM policies after fininshing the TEST.
01-Jun-2023 04:56
just I edited my last reply , look at it 🙂
07-Jun-2023 17:58
Hi @Muthu_435 - were you able to get it working with @Mohamed_Ahmed_Kansoh's advice?
