Technical Forum
Custom Alert Banner
Virtual and pool current connections differs a lot, is it normal?
O__Nilssen
The virtual prod_https_vs is using the pool prod_https_pool, the current connections quantities is far from the same. What may be the explanation for this?
show ltm virtual prod_https_vs
Current Connections           4.9K
show ltm pool prod_https_pool
Current Connections           751
4 REPLIES 4
Do you have any Oneconnect and/or Persistence profile configured on the vServer ?
hi, yes to both.
Then the results that you are seeing are normal. Due to oneconnect profile, exiting idle connections gets reused while sending request to the pool member. So the new server-side connection won't be initiated with pool member if the existing idle connection is available for reuse for other client requests.
ok, that make sense, thank you 🙂
