SSHSSH_97332
Dec 08, 2012Nimbostratus
VIPRION HA Ports
i ahve VIPRION with with 3 interfaces carrying traffic , all are 10G interfaces
can i use 1G for HA , as i think HA is only connection mirroring & heart beats .
If you are mirroring layer 7 connections then the full payload must be sent to the peer and you'd probably want to use a 10G interface. If not, a 1Gb port should be fine.
That said, there is generally very limited value in L7 mirroring as most protocols can handle a connection drop.
Aaron
