Technical Forum
vip call another vip with internal ip
MAbbas
Cirrus
Cirrus
hello ,
i want to resolve a problem
Vip one gets a request from internet -- if URI is abc - an internal Virtual is selected -
and on the internal VIP - only F5 s ip is allowed meaning - no external calls on the internal VIP -
so - if i add a irule to select vip - how would i chaneg ip as well
1 ACCEPTED SOLUTION
Angelo_V
Cirrus
Cirrus
you can override the SNAT configuration in irule:
https://clouddocs.f5.com/api/irules/snat.html
3 REPLIES 3
Which IP are you looking to change ? Do you mean destination or source IP ?
MAbbas
Cirrus
Cirrus
i want to change both -- meaning a new call to an internal VIP
Angelo_V
Cirrus
Cirrus
