26-Jul-2023 00:57
Recommendation:
- Reseat the blade that has the Error of VM.
It resolves after it reseats the blade that has the errors of VM.
F5 Platform: Viprion C4800 | B4300
BIGIP version: BIG-IP 14.1.5.5
26-Jul-2023 05:13
I would try to set the vCMP guest to configured, and then toggle back to deployed and see if that resolves the issue. Also, those blades are quite old.... it has passed the Hardware Product End of Software Support
(EoSS) as of 01-Apr-2021. Complete hardware support ends 01-Apr-2025.
https://my.f5.com/manage/s/article/K4309
In either case, you also want to be getting off BIG-IP 14.x as this will be toast by December 31, 2023.
https://my.f5.com/manage/s/article/K5903
26-Jul-2023 06:11
I've tried multiple times to change the status mode of guests. Blade reseat only resolves the issue.
I appreciate your comment. thank you
26-Jul-2023 06:14
You may need to submit a support case with F5 support if you want to figure out root cause.
