Using the F5 LTM for publishing the RSA Auth manager selfservice console
hi out there I am facing a probably simple problem which I can see has been done by several others here - but I havent found a working "Cook-book" for the solution.
I need to publish the self-service portal for the RSA auth manager 8.x trough the F5 LTM with a public URL like "https://rsa.public-zone.com:7004/Selfservice-console which has to be rewritten to f.ex "; To do this I expect that I need to import the SSL certificate from the RSA auth manager, import this in the F5 as a SSL cert and use this in a ssl server-profile But if I just pull-out the certificate from the browser when connected to the intern rsa site and export it to a file - can I use this for this purpose? I think this is my main problem because the re-writing of the URL's should not be a problem. The redirect from the the "root" url ; to https://rsa.public-zone.com:7004/Selfservice-console should not be a huge problem - I would expect this could be done with a policy or maybe simpler with a irule Can some please share what they have done to get this running? br /ti
