Sort By
- kpiti_52215NimbostratusYour post is rather brief but I believe you have the same problem as I do so I'll elaborate this a bit further.
+ Running data query [11]. + Found type = '3' [SNMP Query]. + Found data query XML file at '/admin1/cacti/v0.8.7i-PIA-3.1/resource/snmp_queries/f5_bigip_vs.xml' + XML file parsed ok. + missing in XML file, 'Index Count Changed' emulated by counting oid_index entries + Executing SNMP walk for list of indexes @ '.1.3.6.1.4.1.3375.2.2.10.2.3.1.1' Index Count: 0 + No SNMP data returned
snmpwalk -v2c -c *** x.x.x.x .1.3.6.1.4.1.3375.2.2.10.2.3.1.1 | egrep "^.*\.3375\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.(.*)$"|wc 65 260 11420
- Reynaldo_76704NimbostratusHello Kpiti, i have exactly the same issue: "Executing SNMP walk for list of indexes @ '.1.3.6.1.4.1.3375.2.2.10.2.3.1.1' Index Count: 0
- Reynaldo_76704NimbostratusYou right! i thing the problem is with "/" character tha now appears in the name of Virtual Servers, in this new version the name of virtual server is in the way that you told me..
- kpiti_52215NimbostratusI've been digging further on this one. It seems the rrd file is actually being updated, but all the values are NaN or non existent. So the problem must be somewhere in the Data Queries part of the Cacti process.. I've searched around cacti forums and as I can't really understand why, it seems to work if you set SNMP version to 1 in cacti for that host.. At least you get the list in Verbose Query. You need to delete the old pools and VS graphs/data sources and create new ones with /Common/ or whatever partition you have..
- kpiti_52215NimbostratusOk, this got even weirder, but I got the workaround - can hardly call this a solution.. The way I had to do it is like this:
- notscudNimbostratusHas anyone figured this out? I am having the same problem on v11.5.2 Any query with forward slashes fails
