[URGENT] - Need help on Irule for URL/URI redirect
Sarovani
We want all the request comming to www.example.fr from specific source 10.10.10.1 to get redirected to www.example.fr/ckpartner/ and this should be logged .
Can you please with the below Irule we can achieve this ? Or any modification is required for this .
if { ([IP::addr [IP::client_addr] equals 10.10.10.1]) && ([HTTP::host] starts_with "www.example.fr") } {
log local0.
set newUri [string map {"/" "ckpartner/"} [HTTP::uri]]
HTTP::uri $newUri
4 REPLIES 4
You can try something like this:
when HTTP_REQUEST { if { ([HTTP::host] equals "www.example.fr") } { HTTP::redirect "www.example.fr/ckpartner" log local0. "Client IP [IP::client_addr] has been redirected" } }
Thanks Rodrigo ,
This Irule should only redirect when external users are trying to access the VIP , So we don't want this to impact the internal clients ...So we want to redirect only when we see request from specific external clients .
Then you can use a class match function along with a data group to define your external IP ranges you want redirected.
Something like this:
when HTTP_REQUEST { if { ([HTTP::host] equals "www.example.fr") and [class match [IP::client_addr] equals "specific_external_client_range_data_group"] } { HTTP::redirect "www.example.fr/ckpartner" log local0. "Client IP [IP::client_addr] has been redirected" } }
To create a data group you can use tmsh create /ltm data-group...
I'd also advise you to look into LTM policies as they might be more efficient.
Please, test it first 🙂
Thanks for your help ,
My requirement is currently working with below Irule but I would like to add Datagroup to below Irule so that I can filter more external IP's
Could you please help me modify this irule .
I tried but I got error "variable reference required preeciding $"
if {
                 ([IP::client_addr] contains "10.10.10.1%70") && ([string tolower [HTTP::uri]] contains "/cklauncher/")
                drop
elseif { [string tolower [HTTP::path]] equals "/" && ( [IP::addr [IP::client_addr] equals 10.10.10.1%70]) } {
# redirect the request
log local0. "issuing redirect request to [HTTP::host][HTTP::uri] from [IP::client_addr]"
HTTP::redirect https://[getfield [HTTP::host] ":" 1]/ckpartner/
