Galactico_76554's avatar
Galactico_76554
Mar 06, 2012
Uptime
What is the command to see the uptime of my unit?.
lb01(Active)(tmos.sys.version) show
Sys::Version
Main Package
Product BIG-IP
Version 10.2.1
Build 511.0
Edition Hotfix HF3
Date Sat Apr 16 22:58:45 PDT 2011
  • hoolio's avatar
    hoolio
    uptime or if you are in tmsh, run /util bash -c uptime
    Aaron
  • Hello Aaron,
    I tried with -c option and i get error.
    ___________________________________________
    lb01(Active)(tmos) /util bash -c uptime
    Syntax Error: unexpected argument "-c"
    lb01(Active)(tmos)
    lb01(Active)(tmos.util.bash) ?
    Modules:
    / TMOS Command Line Interface
    /auth User accounts and authentication
    /cli Local user settings and configuration transactions
    /gtm Global Traffic Manager
    /ltm Local Traffic Manager
    /net Network configuration
    /sys General system configuration
    /util Utility programs that can be run from within tmsh
    /wom WAN Optimization
    Commands:
    create Create new configuration items
    delete Remove configuration items
    edit Update configuration using a text editor
    exit Exit the current command mode
    help View tmsh man pages
    install Install an image or hotfix to a volume
    list View configuration and settings
    load Replace running configuration with configuration files
    modify Update existing configuration items
    quit Quit tmsh
    reboot Reboot the system
    reset-stats Reset runtime statistics
    restart Restart BIG-IP services
    run Run an external program
    save Save the running configuration to configuration files
    show View runtime information, statistics and status
    start Start BIG-IP services
    stop Stop BIG-IP services
    submit Submit a batched transaction
  • nm, got it.
    run util bash -c uptime
    10:17:39 up 195 days, 19:24, 1 user, load average: 0.74, 0.50, 0.46
    Thanks a lot
  • Hi,
    Here are the normal procedure to view uptime of the device for individual and Viprion devices.
    1. Non-Viprion device: uptime
    2. Viprion device:
      1. Go to each slot/blade using ssh command Eg: ssh slot1
      2. Once you are on slot1 use uptime command to view blade1/slot1 status
      3. Do same for other blade/slot
    3. You can use below command for viprion devices clsh uptime
