Anzine's avatar
Anzine
Oct 04, 2023
upgrade vcmp guest at the same time on the same slot impact
hi everyone
Upgrade vcmp guest at the same on the same slot will impact cpu resource or other impact ?
example
Guest A on slot 1 and 2
Guest B on slot 1 and 2
If i upgrade at the same time will impact ?
thanks
