28-Feb-2020 03:32
Hello All,
Can someone help me how can i troubleshoot this issue?
Customers are accessing a VIP:8080 and there are around 2k connections on the VIP.
But at 10:00AM CET everyday, connections are going form 2k to 5k+ for 10mins and then going to back to normal.
Traffic flow is as below
Intranet > DC WAN router > Firewall > router > Loadbalancer > Backend servers.
Please help me how to identify this sudden spike in traffic.
Solved! Go to Solution.
28-Feb-2020 03:57
Hello Siva!
Do you happen to know the source IP of all those connections?
I would start by looking at the connection table during that spike. Something like this...
tmsh show sys connection cs-server-addr <VIP> cs-server-port 8080
If everything comes from the same IP it could possibly narrow your tshoot down to a specific client.
Best of luck!
28-Feb-2020 03:57
Hello Siva!
Best of luck!
01-Mar-2020 11:12
Thank you for the reply. Unfortunately source is entire corp network.. But this command is helpful.
28-Feb-2020 06:01
Please run bigtop -n from bash, it will show you VIPs with highest number of connections. Then please check the timeout value of tcp profile assigned to the VIPs. I faced the same issue and I reduced the timeout value of tcp profile and I saw that all long running connections deleted from the connection table.
