Technical Forum
Troubleshooting steps for SSL VPN slowness issue (APM)
Sarovani
Cirrocumulus
Cirrocumulus
Hi Team ,
Can someone please share the troubleshooting steps to follow to identify and resolve SSL VPN slowness issues?
Usecase :
1.all users from one specific site is facing slowness issue .
2.only few users are facing slowness issue .
2 REPLIES 2
boneyard
MVP
MVP
Are those two different use cases?
If it is some users then it is probably local issues, not related to the SSLVPN. If it is all users (from one site i find odd, or do you mean one destination SSLVPN?) then there might something on the SSLVPN side which can be changed.
In any case I would involve F5 support. You will probably try some different settings and check on results, perhaps packet captures. F5 support can actually look into your system with you and determine all these things. Doing that via a forum like this gets complicated and possibly impossible to share confidential information.
Thanks for the reply ..Currently I am not facing any issue ..But I just wanted to know the troubleshooting approach in eacha case .
1.all users from one specific site accessig one destination VPN is facing slowness issue .
2.only few users from one specific site accessig one destination VPN is facing slowness issue .
