Technical Forum
Transfer failed when file using vsftpd is 0 byte
Ponta
My BIG-IP system has the following configuration.
FireWall (Juniper) is the top of BIG-IP4600 (ver 13.1.1.4). From there, a number of VPN tunnels to the remote VPN router are set up.
The remote VPN router has multiple FTP servers (NW cameras) and constantly sends data to vsftpd under the BIG-IP system in active FTP mode.
The FTP server timeout is very short. About 10 seconds?
In my BIG-IP system, multiple virtual servers are set as FTP destinations for an FTP server (NW camera).
ltm virtual FTP_VIP01 {
  address-status yes
  app-service none
  auth none
  auto-lasthop default
  bwc-policy none
  clone-pools none
  cmp-enabled yes
  connection-limit 0
  description none
  destination "FTP DST address":ftp
  enabled
  fallback-persistence none
  flow-eviction-policy none
  gtm-score 0
  ip-protocol tcp
  last-hop-pool none
  mask 255.255.255.255
  metadata none
  mirror disabled
  mobile-app-tunnel disabled
  nat64 disabled
  partition Common
  per-flow-request-access-policy none
  persist none
  policies none
  pool "POOL of vsftpd client"
  profiles {
    tcp {
      context all
    ftp {
      context all
  rate-class none
  rate-limit disabled
  rate-limit-dst-mask 0
  rate-limit-mode object
  rate-limit-src-mask 0
  related-rules none
  rules none
  security-log-profiles none
  service-down-immediate-action none
  service-policy none
  source 0.0.0.0/0
  source-address-translation {
    pool none
    type automap
  source-port preserve
  syn-cookie-status not-activated
  traffic-classes none
  translate-address enabled
  translate-port enabled
  transparent-nexthop none
  urldb-feed-policy none
  vlans none
  vlans-disabled
  vs-index 428
I am facing a problem now.
Occurs when the line between the FTP server (NW camera) and the BIG-IP system is unstable.
The FTP server (NW camera) notifies vsftpd of the file name via the BIG-IP system on the connection on port 21. The FTP server (NW camera) does not try to retrieve files via the BIG-IP system.
The strange thing is that the file is 0 bytes and only the name exists in the destination directory.
I have investigated a lot about this phenomenon. When executing tcpdump with vsftpd, "Response: 426 Failure reading reading network stream" was sent from vsftpd to the BIG-IP system.
Then, if the corresponding file name was deleted from the destination directory, the file was successfully received. (Not 0 byte)
However, if the FTP server (NW camera) and BIG-IP system line become unstable, this phenomenon will reoccur.
Is this related to the configuration of the ftp profile on the BIG-IP system?
I want to hear your opinion.
By the way, this phenomenon does not occur with BIG-IP3900 (ver 10.2.2).why?
0 REPLIES 0
