Saeedbabaei24's avatar
Saeedbabaei24
Jul 07, 2020
TMM memory leaking due to log publisher configuration
Hi dears
I use F5 CGNAT module and I define a log publisher on F5 for remote logging. I have memory leaking problem: tmm memory increase during the time.
F5 version:    14.1.2.3
picture1:
https://ibb.co/YDN88Bz
After analyzing "show sys memory" output we notice that memory leaking is because of Log profile:
picture2:
https://ibb.co/4m3snGt
For troubleshooting I look at logs in tmm using "# cat /var/log/tmm"   and notice that there are a lot of logs telling here is a problem with publisher:
# cat /var/log/tmm
<13> Jul  7 03:51:24 slot1/f5-one notice alg_hs_log_alg_event/1190: errdefs publisher log failure
Now the question is: How can I analyze these logs and find solution for tmm memory leaking?
Any one knows "logger" tool ? or Someone has encountered this problem before?
We have this problem for a long time. And it has not been resolved by updating the version.
picture3:
https://ibb.co/R9dYLdM
picture4:
https://ibb.co/nfYJvd0
Sys::Provision
Module CPU (%) Memory (MB) Host-Memory (MB) Disk (MB)
afm          0           0                0         0
am           0           0                0         0
apm          0           0                0         0
asm          0           0                0         0
avr          1        1888              768      7800
dos          0           0                0         0
fps          0           0                0         0
gtm          0           0                0         0
host        10       20030                0    527856
ilx          1           0            12102         0
lc           0           0                0         0
ltm          1           0                0         0
pem          0           0                0         0
sslo         0           0                0         0
swg          0           0                0         0
tmos        87       42478              700         0
urldb        0           0                0         0
vcmp         0           0                0         0
thanks.
