joao's avatar
joao
Nov 13, 2019
TFTP Load Balancing
TFTP Load Balancing in version 14.1 ?
i try to find some articles for TFTP in release 14.1 but did not find, only for old versions
br,
jl
  • I found the solution:
    One vIP. Port 69. Pool member on port 69. Source persistence. iRule:
    when SERVER_CONNECTED {
       listen {
         proto 17
         timeout 60
         bind [LINK::vlan_id] [IP::local_addr] [serverside {UDP::local_port}]
         server [peer {client_addr}] [peer {UDP::client_port}]
         allow [IP::server_addr]
    That’s it. Works.
  • in principle an article about an older version should be fine, only new things are added, not that much changes in existing functionalty.
  • Did you find a working config? I still can't get it to work.
