Technical Forum
System Upgrade
mahjoub
Cirrus
Cirrus
I'm planning to upgrade my F5 system from v12 to 14.1.2, in F5 download page showing a lot of choices, due my limited experience requesting your advice for which option I have to download.
my current system version is 12 VE.
2 REPLIES 2
Hi mahjoub,
You cannot use vm image for upgrade. You need iso image:
BIG-IP v14.x >> 14.1.2.8 >> BIGIP-14.1.2.8-0.0.7.iso >> Select Location
Hi eaa,
thanks a lot for you quick answer, actually I couldn't find this image, would provide any direct link.
