Richard_Grigsb1's avatar
Richard_Grigsb1
Mar 02, 2021
Stumped by regular expression
Requirement: build a health Check to send an api url call to server and parse the return value for key indicators.
URL: rldimedas1.tcbna.net/rest/apigateway/health/all
Crafted Send String: GET /rest/apigateway/health/all HTTP/1.1\r\nHost: rldimedas1.tcbna.net\r\nConnection: Close\r\n\r\n
User name and password required: DEVF5Inside / <password>
Expected return to be parsed:
  "status": "green",
  "elasticsearch": {
    "cluster_name": "DEV_EventDataStore",
    "status": "green",
    "number_of_nodes": "2",
    "number_of_data_nodes": "2",
    "timed_out": "false",
    "active_shards": "388",
    "initializing_shards": "0",
    "unassigned_shards": "0",
    "task_max_waiting_in_queue_millis": "0",
    "port_9240": "ok",
    "response_time_ms": "16"
  "is": {
    "status": "green",
    "diskspace": {
      "status": "up",
      "free": "99419619328",
      "inuse": "152539549696",
      "threshold": "25195916902",
      "total": "251959169024"
    "memory": {
      "status": "up",
      "freemem": "2668806528",
      "maxmem": "3817865216",
      "threshold": "368102604",
      "totalmem": "3681026048"
    "servicethread": {
      "status": "up",
      "avail": "286",
      "inuse": "14",
      "max": "300",
      "threshold": "30"
    "response_time_ms": "103"
  "terracotta": {
    "status": "green",
    "nodes": "2",
    "healthy_nodes": "2",
    "response_time_ms": "67"
3 Key Indicators of healthy Services:
#1
"elasticsearch": {
    "status": "green",
#2
"is": {
    "status": "green",
#3
"terracotta": {
    "status": "green",
I would think it was possible to craft the received string parse to check for all 2 key indicators so I do not have to create 3 separate health checks.
I have tried just checking for the first indication by following suggestion in DevCentral but is did not work:
\"elasticsearch\": \{\"cluster_name\": \"DEV_EventDataStore\",\"status\": \"green\",
This solution is complicated by all 3 indicators being the same syntax: "status": "green"
I think there might be an issue with my GET string as well because the Monitor log only shows "200 OK" as the response from the server.
When I change the receive string to only elasticsearch, it passes.
Any Help Here?
  • I always start my regex development at
    regex101.com
    (\"elasticsearch\")(.*)(\n\B)(\s*.*\n\B)(\s*\"status\": \"green\")
    matches the first stanza.
    It gets harder from there ...
    • Richard_Grigsb1's avatar
      Richard_Grigsb1
      Could the issue actually be in the formatting of my GET string?
      Here is the URL the DEV OPS Team gave me:
      HTTPS:// rldimedas1.tcbna.net/rest/apigateway/health/all
      Here is how I formatted the Send String:
      This request requires a username and password so they have been entered
  • Could you use an external monitor so you can parse the json return data more cleanly than with REGEX? in python, that would be pretty simple:
    from sys import stdout
    resp = '''your json response string'''
    if resp['elasticsearch']['status'] == 'green' and resp['is']['status'] == 'green' and resp['terracotta']['status'] == 'green':
        stdout.write('UP')
    else:
        stdout.write('DOWN')
    UP
    You can find a full python external monitor sample here in the codeshare for RADIUS that you could modify to meet your needs.
  • Issue resolved.
    I discovered that the "Type" and "parent monitor" were set to "HTTPS" but SSL Profile was left at "NONE". I selected a generic ssl profile and the health check started functioning.
    Here is what I end up with for the unique/per server in the pool/heath check.
    Receive String: elasticsearch.*cluster_name.*DEV_EventDataStore.*status.*green.*number_of_nodes.*status.*green.*diskspace.*terracotta.*status.*green.*nodes
    The additional items in the receive string parse are so the F5 does not match subsequent  "status": "green" occurrences in the reply.
    Thank You for your responses.
    I am moving forward with the "monitoring server platform" idea that will provide an UP/DOWN HTML page for the F5 to check.
