Otto_Schmedlap_'s avatar
Otto_Schmedlap_
Jun 23, 2006
Stick to pool even if subsequent URI does not match
I have a need with a 3rd party product to initially match on "/sites/" in the URI but then on subsequent requests the URI may not have "/sites/" in it.
However if I select a hyperlink that is the root "/" or 5 other key words I need to goto another pool.
Can anyone get me started with a hilevel design and iRules?
