Piotr_Lewandows's avatar
Piotr_Lewandows
May 09, 2016
Static routes and VLAN/Tunnel as Resource Type
I was trying to figure out how VLAN/Tunnel type of static route is working. Looking at the GUI help as well as Routing docs I am still puzzled.
I would appreciate some real life example when such setup should be used and how it's working.
Piotr
  • zeiss_63263's avatar
    zeiss_63263
    Historic F5 Account
    Hi Piotr,
    If you're asking what the BIG-IP does when you set a static route to point to a VLAN or tunnel instead of (for example) a next-hop gateway, then the BIG-IP should ARP for the destination address regardless of the configured IP addresses on the interface itself. The BIG-IP will ARP for the destination address using a locally configured source self-ip on that VLAN/tunnel.
    That means that you need a proxy ARP device upstream to see the ARP request and respond.
    In earlier software versions and under certain conditions, the BIG-IP would broadcast packets (L2 ff:ff:ff:ff:ff:ff) to the IP destination when the ARP goes unanswered. Some routers would happily route that, but the behaviour was deemed to be undesirable and should no longer occur.
    Regards, Michael.
  • Hi,
    Thanks a lot for answer. I hope I can understand it now but to be sure..
    Scenario (Route definition):
    • Destination: 192.168.1.0/24
    • Resource: Use VLAN/Tunnel
    • VLAN/Tunnel: VLAN_X
    Now there is a question how VLAN has to be defined:
    • Just VLAN assigned to given Interface
    • As above plus Self IP assigned to VLAN
    Assuming that second option above is true, VLAN_X def is:
    • Self IP: 192.168.2.1/24
    Having above def what will happen when packet with destination IP 192.168.1.1 is processed?
    • BIG-IP broadcast ARP request for 192.168.1.1
    • If there is any proxy ARP device that knows route to 192.168.1.1 it will answer with own MAC
    • BIG-IP will send packet with dst IP 192.168.1.1 and dst MAC of proxy ARP device
    • Proxy ARP device will send this packet using defined route either to destination host or to another upstream device
    Is above correct?
    I wonder what do you mean by "the BIG-IP would broadcast packets (L2 ff:ff:ff:ff:ff:ff) to the IP destination when the ARP goes unanswered" - packet will be send with dst IP 192.168.1.1 and broadcast MAC?
    Piotr
