F5 Container Ingress Services (CIS) deployment using Cilium CNI and static routes
F5 Container Ingress Services (CIS) supports static route configuration to enable direct routing from F5 BIG-IP to Kubernetes/OpenShift Pods as an alternative to VXLAN tunnels.
Static routes are enabled in the F5 CIS CLI/Helm yaml manifest using the argument --static-routing-mode=true.
In this article, we will use Cilium as the Container Network Interface (CNI) and configure static routes for an NGINX deployment
For initial configuration of the BIG-IP, including AS3 installation, please see
https://clouddocs.f5.com/products/extensions/f5-appsvcs-extension/latest/userguide/installation.html and https://clouddocs.f5.com/containers/latest/userguide/kubernetes/#cis-installation
The first step is to install Cilium CNI using the steps below on Linux host:
CILIUM_CLI_VERSION=$(curl -s https://raw.githubusercontent.com/cilium/cilium-cli/main/stable.txt)
CLI_ARCH=amd64
if [ "$(uname -m)" = "aarch64" ]; then CLI_ARCH=arm64; fi
curl -L --fail --remote-name-all https://github.com/cilium/cilium-cli/releases/download/${CILIUM_CLI_VERSION}/cilium-linux-${CLI_ARCH}.tar.gz{,.sha256sum}
sha256sum --check cilium-linux-${CLI_ARCH}.tar.gz.sha256sum
sudo tar xzvfC cilium-linux-${CLI_ARCH}.tar.gz /usr/local/bin
rm cilium-linux-${CLI_ARCH}.tar.gz{,.sha256sum}
cilium install --version 1.18.5
cilium status
cilium status --wait
root@ciliumk8s-ubuntu-server:~# cilium status --wait
/¯¯\__/¯¯\ Cilium: OK
\__/¯¯\__/ Operator: OK
/¯¯\__/¯¯\ Envoy DaemonSet: OK
\__/¯¯\__/ Hubble Relay: disabled
\__/ ClusterMesh: disabled
DaemonSet cilium Desired: 1, Ready: 1/1, Available: 1/1
DaemonSet cilium-envoy Desired: 1, Ready: 1/1, Available: 1/1
Deployment cilium-operator Desired: 1, Ready: 1/1, Available: 1/1
Containers: cilium Running: 1
cilium-envoy Running: 1
cilium-operator Running: 1
clustermesh-apiserver
hubble-relay
Cluster Pods: 6/6 managed by Cilium
Helm chart version: 1.18.3
Image versions cilium quay.io/cilium/cilium:v1.18.3@sha256:5649db451c88d928ea585514746d50d91e6210801b300c897283ea319d68de15: 1
cilium-envoy quay.io/cilium/cilium-envoy:v1.34.10-1761014632-c360e8557eb41011dfb5210f8fb53fed6c0b3222@sha256:ca76eb4e9812d114c7f43215a742c00b8bf41200992af0d21b5561d46156fd15: 1
cilium-operator quay.io/cilium/operator-generic:v1.18.3@sha256:b5a0138e1a38e4437c5215257ff4e35373619501f4877dbaf92c89ecfad81797: 1
cilium connectivity test
root@ciliumk8s-ubuntu-server:~# cilium connectivity test
ℹ️ Monitor aggregation detected, will skip some flow validation steps
✨ [default] Creating namespace cilium-test-1 for connectivity check...
✨ [default] Deploying echo-same-node service...
✨ [default] Deploying DNS test server configmap...
✨ [default] Deploying same-node deployment...
✨ [default] Deploying client deployment...
✨ [default] Deploying client2 deployment...
✨ [default] Deploying ccnp deployment...
⌛ [default] Waiting for deployment cilium-test-1/client to become ready...
⌛ [default] Waiting for deployment cilium-test-1/client2 to become ready...
⌛ [default] Waiting for deployment cilium-test-1/echo-same-node to become ready...
⌛ [default] Waiting for deployment cilium-test-ccnp1/client-ccnp to become ready...
⌛ [default] Waiting for deployment cilium-test-ccnp2/client-ccnp to become ready...
⌛ [default] Waiting for pod cilium-test-1/client-645b68dcf7-s5mdb to reach DNS server on cilium-test-1/echo-same-node-f5b8d454c-qkgq9 pod...
⌛ [default] Waiting for pod cilium-test-1/client2-66475877c6-cw7f5 to reach DNS server on cilium-test-1/echo-same-node-f5b8d454c-qkgq9 pod...
⌛ [default] Waiting for pod cilium-test-1/client-645b68dcf7-s5mdb to reach default/kubernetes service...
⌛ [default] Waiting for pod cilium-test-1/client2-66475877c6-cw7f5 to reach default/kubernetes service...
⌛ [default] Waiting for Service cilium-test-1/echo-same-node to become ready...
⌛ [default] Waiting for Service cilium-test-1/echo-same-node to be synchronized by Cilium pod kube-system/cilium-lxjxf
⌛ [default] Waiting for NodePort 10.69.12.2:32046 (cilium-test-1/echo-same-node) to become ready...
🔭 Enabling Hubble telescope...
⚠️ Unable to contact Hubble Relay, disabling Hubble telescope and flow validation: rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing: dial tcp 127.0.0.1:4245: connect: connection refused"
ℹ️ Expose Relay locally with:
cilium hubble enable
cilium hubble port-forward&
ℹ️ Cilium version: 1.18.3
🏃[cilium-test-1] Running 126 tests ...
[=] [cilium-test-1] Test [no-policies] [1/126]
[=] [cilium-test-1] Skipping test [no-policies-from-outside] [2/126] (skipped by condition)
[=] [cilium-test-1] Test [no-policies-extra] [3/126]
<- snip ->
For this article, we will install k3s with Cilium CNI
root@ciliumk8s-ubuntu-server:~# curl -sfL https://get.k3s.io | sh -s - --flannel-backend=none --disable-kube-proxy --disable servicelb --disable-network-policy --disable traefik --cluster-init --node-ip=10.69.12.2 --cluster-cidr=10.42.0.0/16
root@ciliumk8s-ubuntu-server:~# mkdir -p $HOME/.kube
root@ciliumk8s-ubuntu-server:~# sudo cp -i /etc/rancher/k3s/k3s.yaml $HOME/.kube/config
root@ciliumk8s-ubuntu-server:~# sudo chown $(id -u):$(id -g) $HOME/.kube/config
root@ciliumk8s-ubuntu-server:~# echo "export KUBECONFIG=$HOME/.kube/config" >> $HOME/.bashrc
root@ciliumk8s-ubuntu-server:~# source $HOME/.bashrc
API_SERVER_IP=10.69.12.2
API_SERVER_PORT=6443
CLUSTER_ID=1
CLUSTER_NAME=`hostname`
POD_CIDR="10.42.0.0/16"
root@ciliumk8s-ubuntu-server:~# cilium install --set cluster.id=${CLUSTER_ID} --set cluster.name=${CLUSTER_NAME} --set k8sServiceHost=${API_SERVER_IP} --set k8sServicePort=${API_SERVER_PORT} --set ipam.operator.clusterPoolIPv4PodCIDRList=$POD_CIDR --set kubeProxyReplacement=true --helm-set=operator.replicas=1
root@ciliumk8s-ubuntu-server:~# cilium config view | grep cluster
bpf-lb-external-clusterip false
cluster-id 1
cluster-name ciliumk8s-ubuntu-server
cluster-pool-ipv4-cidr 10.42.0.0/16
cluster-pool-ipv4-mask-size 24
clustermesh-enable-endpoint-sync false
clustermesh-enable-mcs-api false
ipam cluster-pool
max-connected-clusters 255
policy-default-local-cluster false
- The F5 CIS yaml manifest for deployment using Helm
- Note that these arguments are required for CIS to leverage static routes
- static-routing-mode: true
- orchestration-cni: cilium-k8s
- We will also be installing custom resources, so this argument is also required
3. custom-resource-mode: true
Values yaml manifest for Helm deployment
bigip_login_secret: f5-bigip-ctlr-login
bigip_secret:
create: false
username:
password:
rbac:
create: true
serviceAccount:
# Specifies whether a service account should be created
create: true
# The name of the service account to use.
# If not set and create is true, a name is generated using the fullname template
# This namespace is where the Controller lives;
namespace: kube-system
ingressClass:
create: true
ingressClassName: f5
isDefaultIngressController: true
args:
# See https://clouddocs.f5.com/containers/latest/userguide/config-parameters.html
# NOTE: helm has difficulty with values using `-`; `_` are used for naming
# and are replaced with `-` during rendering.
# REQUIRED Params
bigip_url: X.X.X.S
bigip_partition: <BIG-IP_PARTITION>
# OPTIONAL PARAMS -- uncomment and provide values for those you wish to use.
# verify_interval:
# node-poll_interval:
# log_level: DEBUG
# python_basedir: ~
# VXLAN
# openshift_sdn_name:
# flannel_name: cilium-vxlan
# KUBERNETES
# default_ingress_ip:
# kubeconfig:
# namespaces: ["foo", "bar"]
# namespace_label:
# node_label_selector:
pool_member_type: cluster
# resolve_ingress_names:
# running_in_cluster:
# use_node_internal:
# use_secrets:
insecure: true
log-as3-response: true
as3-validation: true
# gtm-bigip-password
# gtm-bigip-url
# gtm-bigip-username
# ipam : true
image:
# Use the tag to target a specific version of the Controller
user: f5networks
repo: k8s-bigip-ctlr
pullPolicy: Always
version: latest
# affinity:
# nodeAffinity:
# requiredDuringSchedulingIgnoredDuringExecution:
# nodeSelectorTerms:
# - matchExpressions:
# - key: kubernetes.io/arch
# operator: Exists
# securityContext:
# runAsUser: 1000
# runAsGroup: 3000
# fsGroup: 2000
# If you want to specify resources, uncomment the following
# limits_cpu: 100m
# limits_memory: 512Mi
# requests_cpu: 100m
# requests_memory: 512Mi
# Set podSecurityContext for Pod Security Admission and Pod Security Standards
# podSecurityContext:
# runAsUser: 1000
# runAsGroup: 1000
# privileged: true
- Installation steps for deploying F5 CIS using helm can be found in this link
- Once F5 CIS is validated to be up and running, we can now deploy the following application example
root@ciliumk8s-ubuntu-server:~# cat application.yaml
apiVersion: cis.f5.com/v1
kind: VirtualServer
metadata:
labels:
f5cr: "true"
namespace: nsgoblin
spec:
host: goblin.com
pools:
- path: /green
service: svc-nodeport
servicePort: 80
- path: /harry
servicePort: 80
virtualServerAddress: X.X.X.X
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: nsgoblin
spec:
replicas: 2
selector:
matchLabels:
app: goblin-backend
template:
metadata:
labels:
app: goblin-backend
spec:
containers:
- name: goblin-backend
image: nginx:latest
ports:
- containerPort: 80
apiVersion: v1
kind: Service
metadata:
namespace: nsgoblin
spec:
selector:
app: goblin-backend
ports:
- port: 80
targetPort: 80
type: ClusterIP
k apply -f application.yaml
- We can now verify the k8s pods are created.
- Then we will create a sample html page to test access to the backend NGINX pod
root@ciliumk8s-ubuntu-server:~# k -n nsgoblin get po -owide
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
goblin-backend-7485b6dcdf-d5t48 1/1 Running 0 6d2h 10.42.0.70 ciliumk8s-ubuntu-server <none> <none>
goblin-backend-7485b6dcdf-pt7hx 1/1 Running 0 6d2h 10.42.0.97 ciliumk8s-ubuntu-server <none> <none>
root@ciliumk8s-ubuntu-server:~# k -n nsgoblin exec -it po/goblin-backend-7485b6dcdf-pt7hx -- /bin/sh
# cat > green <<'EOF'
<!DOCTYPE html>
> > <html>
> <head>
<title>Green Goblin</title>
<style>
body { background-color: #4CAF50; color: white; text-align: center; padding: 50px; }
h1 { font-size: 3em; }
> > > > > </style>
</head>
<body>
<h1>I am the green goblin!</h1>
<p>Access me at /green</p>
</body>
</html>
> > > > > > > EOF
root@ciliumk8s-ubuntu-server:~# k -n nsgoblin exec -it goblin-backend-7485b6dcdf-d5t48 -- /bin/sh
> <!DOCTYPE html>
<html>
<head>
<style>
</style>
> </head>
<body>
</body>
</html>
EOF> > > > > > > > > > > > >
- We can now validate the pools are created on the F5 BIG-IP
root@(ciliumk8s-bigip)(cfg-sync Standalone)(Active)(/kubernetes/Shared)(tmos)# list ltm pool all
ltm pool svc_nodeport_80_nsgoblin_goblin_com_green {
description "crd_10_69_12_40_80 loadbalances this pool"
members {
/kubernetes/10.42.0.70:http {
address 10.42.0.70
/kubernetes/10.42.0.97:http {
address 10.42.0.97
min-active-members 1
partition kubernetes
ltm pool svc_nodeport_80_nsgoblin_goblin_com_harry {
members {
address 10.42.0.70
address 10.42.0.97
root@(ciliumk8s-bigip)(cfg-sync Standalone)(Active)(/kubernetes/Shared)(tmos)# list ltm virtual crd_10_69_12_40_80
ltm virtual crd_10_69_12_40_80 {
creation-time 2025-12-22:10:10:37
description Shared
destination /kubernetes/10.69.12.40:http
ip-protocol tcp
last-modified-time 2025-12-22:10:10:37
mask 255.255.255.255
persist {
/Common/cookie {
default yes
policies {
crd_10_69_12_40_80_goblin_com_policy { }
profiles {
/Common/f5-tcp-progressive { }
/Common/http { }
serverssl-use-sni disabled
source 0.0.0.0/0
source-address-translation {
type automap
translate-address enabled
translate-port enabled
vs-index 2
CIS log output
2025/12/22 18:10:25 [INFO] [Request: 1] cluster local requested CREATE in VIRTUALSERVER nsgoblin/goblin-virtual-server
2025/12/22 18:10:25 [INFO] [Request: 1][AS3] creating a new AS3 manifest
2025/12/22 18:10:25 [INFO] [Request: 1][AS3][BigIP] posting request to https://10.69.12.1 for tenants
2025/12/22 18:10:26 [INFO] [Request: 2] cluster local requested UPDATE in ENDPOINTS nsgoblin/svc-nodeport
2025/12/22 18:10:26 [INFO] [Request: 3] cluster local requested UPDATE in ENDPOINTS nsgoblin/svc-nodeport
2025/12/22 18:10:43 [INFO] [Request: 1][AS3][BigIP] post resulted in SUCCESS
2025/12/22 18:10:43 [INFO] [AS3][POST] SUCCESS: code: 200 --- tenant:kubernetes --- message: success
2025/12/22 18:10:43 [INFO] [Request: 3][AS3] Processing request
2025/12/22 18:10:43 [INFO] [Request: 3][AS3] creating a new AS3 manifest
2025/12/22 18:10:43 [INFO] [Request: 3][AS3][BigIP] posting request to https://10.69.12.1 for tenants
2025/12/22 18:10:43 [INFO] Successfully updated status of VirtualServer:nsgoblin/goblin-virtual-server in Cluster
W1222 18:10:49.238444 1 warnings.go:70] v1 Endpoints is deprecated in v1.33+; use discovery.k8s.io/v1 EndpointSlice
2025/12/22 18:10:52 [INFO] [Request: 3][AS3][BigIP] post resulted in SUCCESS
2025/12/22 18:10:52 [INFO] [AS3][POST] SUCCESS: code: 200 --- tenant:kubernetes --- message: success
2025/12/22 18:10:52 [INFO] Successfully updated status of VirtualServer:nsgoblin/goblin-virtual-server in Cluster
Troubleshooting:
1. If static routes are not added, the first step is to inspect CIS logs for entries similar to these:
Cilium annotation warning logs
2025/12/22 17:44:45 [WARNING] Cilium node podCIDR annotation not found on node ciliumk8s-ubuntu-server, node has spec.podCIDR ?
2025/12/22 17:46:41 [WARNING] Cilium node podCIDR annotation not found on node ciliumk8s-ubuntu-server, node has spec.podCIDR ?
2025/12/22 17:46:42 [WARNING] Cilium node podCIDR annotation not found on node ciliumk8s-ubuntu-server, node has spec.podCIDR ?
2025/12/22 17:46:43 [WARNING] Cilium node podCIDR annotation not found on node ciliumk8s-ubuntu-server, node has spec.podCIDR ?
2. These are resolved by adding annotations to the node using the reference: https://clouddocs.f5.com/containers/latest/userguide/static-route-support.html
Cilium annotation for node
root@ciliumk8s-ubuntu-server:~# k annotate node ciliumk8s-ubuntu-server io.cilium.network.ipv4-pod-cidr=10.42.0.0/16
root@ciliumk8s-ubuntu-server:~# k describe node | grep -E "Annotations:|PodCIDR:|^\s+.*pod-cidr"
Annotations: alpha.kubernetes.io/provided-node-ip: 10.69.12.2
io.cilium.network.ipv4-pod-cidr: 10.42.0.0/16
PodCIDR: 10.42.0.0/24
3. Verify a static route has been created and test connectivity to k8s pods
root@(ciliumk8s-bigip)(cfg-sync Standalone)(Active)(/kubernetes)(tmos)# list net route
net route k8s-ciliumk8s-ubuntu-server-10.69.12.2 {
description 10.69.12.1
gw 10.69.12.2
network 10.42.0.0/16
Using pup (command line HTML parser) -> https://commandmasters.com/commands/pup-common/
root@ciliumk8s-ubuntu-server:~# curl -s http://goblin.com/green | pup 'body text{}'
Access me at /green
1 0.000000 10.69.12.34 ? 10.69.12.40 TCP 78 34294 ? 80 [SYN] Seq=0 Win=64240 Len=0 MSS=1460 SACK_PERM TSval=2984295232 TSecr=0 WS=128
2 0.000045 10.69.12.40 ? 10.69.12.34 TCP 78 80 ? 34294 [SYN, ACK] Seq=0 Ack=1 Win=23360 Len=0 MSS=1460 WS=512 SACK_PERM TSval=1809316303 TSecr=2984295232
3 0.001134 10.69.12.34 ? 10.69.12.40 TCP 70 34294 ? 80 [ACK] Seq=1 Ack=1 Win=64256 Len=0 TSval=2984295234 TSecr=1809316303
4 0.001151 10.69.12.34 ? 10.69.12.40 HTTP 149 GET /green HTTP/1.1
5 0.001343 10.69.12.40 ? 10.69.12.34 TCP 70 80 ? 34294 [ACK] Seq=1 Ack=80 Win=23040 Len=0 TSval=1809316304 TSecr=2984295234
6 0.002497 10.69.12.1 ? 10.42.0.97 TCP 78 33707 ? 80 [SYN] Seq=0 Win=23360 Len=0 MSS=1460 WS=512 SACK_PERM TSval=1809316304 TSecr=0
7 0.003614 10.42.0.97 ? 10.69.12.1 TCP 78 80 ? 33707 [SYN, ACK] Seq=0 Ack=1 Win=64308 Len=0 MSS=1410 SACK_PERM TSval=1012609408 TSecr=1809316304 WS=128
8 0.003636 10.69.12.1 ? 10.42.0.97 TCP 70 33707 ? 80 [ACK] Seq=1 Ack=1 Win=23040 Len=0 TSval=1809316307 TSecr=1012609408
9 0.003680 10.69.12.1 ? 10.42.0.97 HTTP 149 GET /green HTTP/1.1
10 0.004774 10.42.0.97 ? 10.69.12.1 TCP 70 80 ? 33707 [ACK] Seq=1 Ack=80 Win=64256 Len=0 TSval=1012609409 TSecr=1809316307
11 0.004790 10.42.0.97 ? 10.69.12.1 TCP 323 HTTP/1.1 200 OK [TCP segment of a reassembled PDU]
12 0.004796 10.42.0.97 ? 10.69.12.1 HTTP 384 HTTP/1.1 200 OK
13 0.004820 10.69.12.40 ? 10.69.12.34 TCP 448 HTTP/1.1 200 OK [TCP segment of a reassembled PDU]
14 0.004838 10.69.12.1 ? 10.42.0.97 TCP 70 33707 ? 80 [ACK] Seq=80 Ack=254 Win=23552 Len=0 TSval=1809316308 TSecr=1012609410
15 0.004854 10.69.12.40 ? 10.69.12.34 HTTP 384 HTTP/1.1 200 OK
Summary:
There we have it, we have successfully deployed an NGINX application on a Kubernetes cluster managed by F5 CIS using static routes to forward traffic to the kubernetes pods
