Abed_AL-R's avatar
Abed_AL-R
Jan 16, 2020
SSO for Portal Access resource item
Hi
I was hoping someone could help me with creating SSO for web application published through F5 APM
I got SSO working for RDP sessions and there was not problem to got it woking. But for the web application I'm not sure about some settings..
The web application is configured in the Portal Access
And I configured Single-Sign-On Forum Based. For Credentials Source I set the following:
session.ldap.last.attr.userPrincipalName
session.logon.last.password
(This what is configured for RDP SSO , and there it is working fine.)
For this forum SSO I used:
session.logon.last.username
Anyway, for the start URI not sure what to put there, neither for the Form Action
When the user is logged into the F5 APM, he click on the portal access application link, and then he got the application webpage:
https://myapm.mydomain.com/f5-w-687474703a2f2f3137322e32312e31322e32$$/mclient/
then automatically to the login page:
https://myapm.mydomain.com/f5-w-687474703a2f2f3137322e32312e31322e32$$/mclient/#/login
How should I treat the: /f5-w-<hex encoded scheme>$$/path ?
Should I use wildcard for this situation? linke this for example:
*/mclient/#/login
For the forum action (POST action) it is also using the /f5-w-<hex encoded scheme>$$/path ....
Any advise?
  • BIG-IP will decode the hex-encoded scheme so just forget about that and deal with the non-encoded URI ie the start page could be /mclient/ and the form action might be /mclient/#/login ( assuming it actually is - worth checking the actual form that is presented )
