Technical Forum
SSl TPS calculation
Arunakshi
Please help me to understand how to calculate ssl tps?
SSL cert for an existing VS is being upgraded from 2048 to 4096. Before upgrade , the ssl traffuc generates an average of 3000 SSL TPS. The bigip hardware supports 4000 ssl tps ( 2048 keysize). So upto what ssl tps the bigip should be upgraded to ?
1 ACCEPTED SOLUTION
Check this article: https://support.f5.com/csp/article/K6475
If I understand correctly, you'll need a license for 15000 SSL TPS.
The 4000 SSL TPS is valid for keys with a size from 2048 to 4095 bits. For 4096 bit keys the 4000 SSL TPS license is 20% of the licensed TPS, so 800 SSL TPS. If you need 3000 SSL TPS in use with 4096 bit keys, you'll need a license of 15000 SSL TPS. In this case an I4800 appliance will do ( 20K SSL TPS license).
2 REPLIES 2
Arunakshi
thanks a lot Niels..may i check with you what if we change the key size for a virtual server instead of whole device..
