05-Jun-2023 12:07
Current flow is as below
Client -> F5 LTM (SSL Proxying) -> On premise Application Servers (TLS Offloading).
Certificates that do TLS offloading has F5 LTM DNS as CN/SAN.
For a migration of my on premise application stack to cloud, I need to achieve below two cases.
Client -> F5 LTM (SSL offloading for specific client IPs & Reencrypt TLS) -> New Stack cloud Application
I have went through Bypass ssl offloading to certain IPs - DevCentral (f5.com) & SSL Offloading using iRules - DevCentral (f5.com). But not the exact case. Would wanted to confirm with experts here in thr forum please. Can someone kindly shed some light & a small example please?
Solved! Go to Solution.
05-Jun-2023 14:30
Something like this maybe (where offload_ips is a data-group with ip host and ip/mask as specified)
when CLIENT_ACCEPTED priority 500 {
if {[class match -- [IP::client_addr] equals offload_ips]} {
SSL::enable
pool new_stack_cloud_application
SSL::disable
pool on_premise_applications_servers
05-Jun-2023 23:29 - edited 05-Jun-2023 23:33
@JRahm, I beg to differ and offer a different solution. Not every problem requires an iRule to be solved. 🙂
I'd rather create two virtual servers, one with pool_A and SSL Bridging configured and another one with pool_B and SSL Passthrough, and make use of K14800: Order of precedence for virtual server matching.
Order | Destination | Source | Port |
1 | (host address) | (network address) | (port) |
2 | (host address) | * | (port) |
For the source you can use an Address List as described in this Manual article: Configuring Multiple IP Addresses and Service Ports for a Virtual Server. This would replace the datagroup for matching the source IP address(es).
KR
Daniel
05-Jun-2023 14:30
SSL::enable
SSL::disable
05-Jun-2023 14:40
Thanks JRahm, this helps!
05-Jun-2023 14:44
untested...make sure to test in a lab! if you have trouble I might be able to mock up tomorrow.
05-Jun-2023 14:49
Unfortunately I dont own F5 LTM environment to test it. So would be passing across your solution to them. Would let you know in case of any issues during implementation. Thanks much.
KR
Daniel
06-Jun-2023 00:32
Hi Daniel,
Thanks for additional solution. Will weigh out this approach as well. But here for each phase of migration, when I need to add client IP / Inbound Source IP address, I need to make changes in Virtual Server Config which is bit risky isn't it? With iRules, I would need to edit "offload_ips" data group alone. Something similar to config management.
06-Jun-2023 01:11
Hi @maadavan,
you would either have to add the IP addresses to the datagroup or to the access list, but not to the virtual server directly. So it is equally risky. Not risky at all, in my opinion.
KR
Daniel
06-Jun-2023 01:22
Hi Daniel,
Thanks for clarifying. On that case, happy with multiple feasible solution. Will forward both viable solution to F5 implementation team for their views & ease of implementation & maintenance.
Thanks once again.
Cheers,
Maadavan
06-Jun-2023 08:16
@Daniel_Wolf HOW DARE YOU BEG TO DIFFER!! 😎
But seriously, 💯 on only using iRules where necessary. @maadavan, this solution is definitely the way to go!
06-Jun-2023 08:39
I'm always looking for trouble... 😁😁😁
06-Jun-2023 09:18
Thanks for clarifying & providing quick solutions @JRahm , @Daniel_Wolf
