LA_Medina_32319's avatar
LA_Medina_32319
Apr 11, 2018
SSL Handshake Failure
We are having trouble with one of our newly created VS. It cant seem to be able to 'communicate' to the backend server (NODEs).
We have reachability to the Node IP. We also have an existing VS with NODE IPs from the same subnet as the new one and it is working fine. The setting is identical as well from the working one.
When i did a curl check, i can see that there was an error on the SSL but i cant figure out where the issue is, whether it is on the F5 or on the server end. I don't have access/visibility on the server end so i'm unable to do some check and verification on server end.
We have configured a SSL Client and Server Profile in the VS.
Was wondering if someone can shed some light on this. Would appreciate it much!
Below is the error i get for the SSL.
[Active:In Sync] config  curl -vk https://[Node IP]
* About to connect() to [Node IP] port 443 (0)
*   Trying [Node IP]... connected
* Connected to [Node IP] ([Node IP]) port 443 (0)
* successfully set certificate verify locations:
*   CAfile: /etc/pki/tls/certs/ca-bundle.crt
  CApath: none
* SSLv3, TLS handshake, Client hello (1):
* Unknown SSL protocol error in connection to [Node IP]:443
* Closing connection 0
curl: (35) Unknown SSL protocol error in connection to [Node IP]:443
Below is the setting/config of the VS:
(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual [VS Name] all-properties
ltm virtual [VS Name] {
    address-status yes
    app-service none
    auth none
    auto-lasthop default
    bwc-policy none
    clone-pools none
    cmp-enabled yes
    connection-limit 0
    description none
    destination [VS IP]:https
    enabled
    fallback-persistence none
    flow-eviction-policy none
    gtm-score 0
    ip-protocol tcp
    last-hop-pool none
    mask 255.255.255.255
    metadata none
    mirror disabled
    mobile-app-tunnel disabled
    nat64 disabled
    partition Common
    per-flow-request-access-policy none
    persist {
        cookie {
            default yes
    policies none
    pool [Pool Name]
    profiles {
        [SSL Profile] {
            context clientside
        http {
            context all
        serverssl {
            context serverside
        tcp {
            context all
    rate-class none
    rate-limit disabled
    rate-limit-dst-mask 0
    rate-limit-mode object
    rate-limit-src-mask 0
    related-rules none
    rules none
    security-log-profiles none
    source 0.0.0.0/0
    source-address-translation {
        pool none
        type automap
    source-port preserve
    syn-cookie-status not-activated
    traffic-classes none
    translate-address enabled
    translate-port enabled
    urldb-feed-policy none
    vlans none
    vlans-disabled
    vs-index 15
Below is the setting/config of a working VS that has a node ip from the same subnet.
    address-status yes
    app-service none
    auth none
    bwc-policy none
    clone-pools none
    cmp-enabled yes
    connection-limit 0
    description "description"
    enabled
    gtm-score 0
    ip-protocol tcp
    last-hop-pool none
    metadata none
    mirror disabled
    nat64 disabled
    partition Common
    persist {
        cookie {
            default yes
    policies none
    pool [Pool Name]
    profiles {
        [SSL Profile] {
            context clientside
        http {
            context all
        serverssl {
            context serverside
        tcp {
            context all
    rate-class none
    rate-limit disabled
    related-rules none
    rules none
    source 0.0.0.0/0
        pool none
        type automap
    vlans none
    vlans-disabled
    vs-index 4
  • Forgot to mention HTTPS monitor doesn't work on the Pool. It is marking the node down which would explain the SSL failure. So right now i just used ICMP as a monitor first just to bring the Node up.
  • JG's avatar
    JG
    Please share the output of:
    openssl s_client -connect node_addr:port
  • Are you nodes ssl or non-ssl.
    If they are non ssl nodes, there's no point of putting https monitor, it will fail. You gotta try putting http monitor.
    Having node ip from the same subnet does not mean it is ssl server. Maybe the one working is having ssl enabled and thats why https monitor is put and like wise a serverssl profile.
    But if your current non-working is non ssl, put http monitor and remove serverssl profile. Try http instead of https.
    curl -vk http://[Node IP]
    If your http/https monitor is marking it as up and still VS is inaccessible, we can troubleshoot further.
  • Hi,
    Does the server require SNI?
    Try
    openssl s_client -connect [node IP]:443 -servername app.company.com
    App.company.com is the application fqdn for which you have a certificate.
