02-May-2019 14:15
We are seeing a ton of these messages in our logs. Several per minute from legit client IPs. However, the clients are not reporting any issues.
SSL Handshake failed for TCP x.x.x.x:11555 -> x.x.x.x:443
These particular messages are NOT followed up a connection error message about an unsupported version as you might expect (for example: Connection error: ssl_hs_rxhello:7699: unsupported version (40)). I am trying to understand what is occurring. I did a pcap but was not able to get much out of it since there was a lot of normal traffic in there as well since these are good source IPs. I did not find any fatal handshake errors. Anything else I could look for in a pcap to see what is occurring? What other instances would you see a message like this? The frequency of the messages increase/decrease with peak and off peak times. The application is a typical IIS web app where the client uses a browser to access.
02-May-2019 15:17
There are many reasons, and some of them don't have to be something bad.
What version are you running?
Look this for example -> https://support.f5.com/csp/article/K11058264
The best way is to analyse this KB carefully -> https://support.f5.com/csp/article/K15292
Also, if you want to see something it's necessary to decrypt the TLS Handshake -> https://support.f5.com/csp/article/K10209
KR, Dario.
17-May-2019
00:46
- last edited on
01-Jun-2023
15:04
by
JimmyPackets
Hey K-Dubb
First thing you need to do is to go to Client SSL profile and disable Generic Alert.
Generic Alert hides (for security reasons) the real reason why your SSL handshake is failing.
This is good from security perspective, but for troubleshooting perspective you can safely disable it temporarily.
I would also advise to temporarily set 'Cache Size' to 0 as you will likely need to see the capture decrypted and decrypting software can only decrypt capture if it gets hold of master key and master key is only available when full TLS handshake takes place.
You can then use the following tcpdump filter to rotate through captures for every 1 GB, for example using -C flag:
$ tcpdump -i 0.0:nnn -s0 <virtual server's IP address> -C 1000 -w /shared/tmp/tls-handshake-errors.pcap -v
This would rotate the capture every 1 GB until you you have enough time to spot the TLS handshake error in the logs.
For more details about tcpdump syntax or if you want to use a different filter, you can follow K65251607 Using tcpdump to create rotating packet capture files.
Notice that you might need to have the capture decrypted so you can see the reason why TLS handshake failed.
If so, you have 2 options depending on the cipher you're using:
1 SSLdump: K10209: Overview of packet tracing with the ssldump utility
-> This would only decrypt capture when cipher chosen has RSA key exchange method
-> If you want to remove non-RSA ciphers temporarily for testing, that is fine too and you'd need to add to Cipher List the following: DEFAULT:!DHE:!ECDHE
2 iRule (Applied to Virtual Server):
when CLIENTSSL_HANDSHAKE {
if {[IP::addr [IP::client_addr] equals TYPE_CLIENT_IP_HERE] } {
log local0. "TCP source port: [TCP::remote_port]"
log local0. "RSA Session-ID:[SSL::sessionid] Master-Key:[SSL::sessionsecret]" }
You can copy the RSA Session-ID bit to a file and load it into Wireshark.
If you want to capture traffic from a specific client the iRule works just fine regardless of the cipher used. If you need an open packet capture I would temporarily disable DHE/ECDHE and use SSLDUMP.
Please, let me know if you have further questions.
Thank you,
Rodrigo
26-Jun-2019 13:59
Does disabling Generic alert give anymore info in the local traffic logs? Or some other log? So far I am seeing the same logs of "SSL Handshake Failure for TCP.." and just a handful of messages with slightly more info and a code that I can't match up to the handshake failure log entry (they are not one to one). Also is there a master list of what each of the SSL codes mean? Thanks!
