Technical Forum
Custom Alert Banner
sshd could not load host key
Nicol4s
Hello,
I'm running a fresh install of BIG IP VE using TMOS 14.1.4.3
The sshd daemon is not able to start because of the following message :
Could not load host key: /config/ssh/ssh_host_rsa_key
When connected using the bash terminal, I can see the content of the key just fine.
I have tried to relabel the filesystem in order to fix the SeLINUX permissions but still no dice.
Procedure that was applied : https://support.f5.com/csp/article/K74412100
thank you.
2 REPLIES 2
Hello Nicol4s.
You just need to recreate your SSH RSA key.
ssh-keygen -t rsa -f /config/ssh/ssh_host_rsa_key
systemctl restart sshd
Let me know if it works in your case.
Regards,
Dario.
Regards,
Dario.
Nicol4s
Hello Dario,
I did something very similar to your solution :
KB Reference used : https://support.f5.com/csp/article/K66144802
bigstart stop sshd
restorecon -rF /config/ssh/ssh_host_*
bigstart restart sshd
journalctl -u sshd
Now the SSH daemon is able to start correctly when my VM boot or reboot.
Thank you for the tip.
Regards.
