Technical Forum
Custom Alert Banner
SNAT node to VIP iRule
Hey everyone -
  • V13
  • All nodes point to F5 as default gateway
  • Forwarding IP VIP 0.0.0.0
We would like outbound connections from each node to SNAT to it's respective VIP IP. Does someone have a configuration/iRule that will work for this? Also, if there was a way to use the same iRule for each VIP (without IP changes), that would be ideal.
So based on configuration below, how can node1 (10.4.55.10) SNAT from existing VIP (10.3.0.10) ?
ltm virtual VIP1 {
    destination 10.3.0.10:5986
    ip-protocol tcp
    mask 255.255.255.255
    pool POOL1
    profiles {
        tcp { }
    source 0.0.0.0/0
    translate-address enabled
    translate-port enabled
ltm pool POOL1 {
    members {
        NODE1:5986 {
            address 10.4.55.10
            session monitor-enabled
            state up
    monitor tcp_half_open
ltm virtual vs_0.0.0.0_any {
    destination 0.0.0.0:any
    ip-forward
    mask any
    profiles {
        fastL4 { }
    source 0.0.0.0/0
    translate-address disabled
    translate-port disabled
net route external_default_gateway {
    gw 10.3.0.1
    network default
net self FLOATING_IP {
    address 10.4.55.1/24
    allow-service all
    floating enabled
    traffic-group traffic-group-1
    unit 1
    vlan NODE1_VLAN
1 REPLY 1
Leonardo_Souza
Cirrocumulus
Cirrocumulus
There are many ways to do that, I will give a couple ones.
First option, multiple virtual servers.
You could create multiple forward virtual servers with destination 0.0.0.0/0 and source as the server ip, and with the snap pool with the IP you want.
Second, single forward virtual server, and irule + datagroup. The iRule would perform the snat based in the source IP and get the snat IP from the datagroup.
Some useful links for that:
https://support.f5.com/csp/article/K14800
https://devcentral.f5.com/wiki/irules.snat.ashx
https://devcentral.f5.com/wiki/irules.class.ashx
