Mohanad's avatar
Mohanad
6 years ago
Solved
iRule for Conditional SNAT
i need to configre iRule for Conditional SNAT while (10.10.10.1 & 10.10.10.2) connecting to the VS SNAT will be 10.214.214.148 and the rest of clients the SNAT will be 10.214.214.147
current setup:
snat pool "DPG-147" = 10.214.214.147 & i have another snat pool "DPG-148" = 10.214.214.148
ltm virtual DPG-Staging-5006
  description Cube
  destination 192.168.30.147:pxc-spvr
  ip-protocol tcp
  mask 255.255.255.255
source 0.0.0.0/0
  source-address-translation
    pool DPG-147
    type snat
Mohanad
  • Hi,
    Do you really need the SNAT pool, or you just need to definean IP address to SNAT on iRule?
    e.g.
    # Classic syntax
    when CLIENT_ACCEPTED {
        if { [IP::client_addr] eq "10.10.10.1" || [IP::client_addr] eq "10.10.10.2" } {
            snat 10.214.214.148
            snat 10.214.214.147
    # Short way
        if { "10.10.10.1, 10.10.10.2" contains [IP::client_addr] } {
            snat 10.214.214.148
            snat 10.214.214.147
    # Expansive way, increase list when needed
        switch [IP::client_addr] {
            10.10.10.1 -
            10.10.10.2 {
                snat 10.214.214.148
            default {
                snat 10.214.214.147
    You must change line from "snat <IP ADDR>" to "snatpool <POOLNAME>" if you need to use a SNAT pool.
    I hope it helps.
  • Hi,
    e.g.
    # Classic syntax
            snat 10.214.214.148
            snat 10.214.214.147
    # Short way
            snat 10.214.214.148
            snat 10.214.214.147
            10.10.10.1 -
            10.10.10.2 {
                snat 10.214.214.148
            default {
                snat 10.214.214.147
    I hope it helps.
    • Mohanad's avatar
      Mohanad
      Thank you cjunior i used pool name for the irule and working successfully
  • Hello.
    I would use also one the cjunior irules, but take into account that it's possible to configure this directly without iRule using 2 virtuals with different source ip. For example.
    	description Cube
    	ip-protocol tcp
    	source 0.0.0.0/0
    	pool DPG-147
    	type snat
    ltm virtual DPG-Staging-5006_2
    	description Cube
    	ip-protocol tcp
    	source 10.10.10.0/30
    	pool DPG-148
    	type snat
    REF - https://support.f5.com/csp/article/K14800
    Also using policies.
    REF - https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/local-traffic-policies-getting-started-12-1-0/1.html
    KR,
    Dario.
