VFB's avatar
VFB
Icon for Cirrus rankCirrus
Jun 22, 2018
SNAT local address going to a specific port
I'm trying to SNAT a subnet going to a specific port but not getting anywhere with the iRule. Below is what I currently have:
when CLIENT_ACCEPTED { if {[IP::addr [IP::client_addr] equals "10.10.10.0/28"]} and {[UDP::local_port] equals "1700"]} {snat "10.10.10.1"}}
  • Braces and brackets are a bit misaligned. Try the following which should at least be syntactically correct:
        if { [IP::addr [IP::client_addr] equals "10.10.10.0/28"] && [UDP::local_port] equals "1700" } {
            snat "10.10.10.1"
