Site can't be reached after enabling URL rewrite in IIS to remove aspx extension
Hi, hope you can help us with this. We are trying to use URL Rewrite on IIS to remove aspx extension from the URL so instead of http://abc.domain.com/status.aspx it will be http://abc.domain.com/status
So after we enable this, it works, but when we put F5 to the equation, the site cannot be reached anymore. In the Pool says the member node is Offline. So seems like F5 doesn't recognize the URL that doesn't have aspx? Do you think if this is something related to Health check? The current Helthcheck is: GET /status.aspx HTTP/1.1\r\nHost: host.domain.com\r\nConnection: Close\r\n\r\n
How can we setup the Health Monitor for the site without the aspx extension? Please advise. Thank you in advance
Hoang
- Ryannnnnnnnn
Altocumulus
If you've modified IIS to rewrite/remove the aspx extension on the status page, wouldn't your health check need to be updated to be
GET /status HTTP/1.1\r\nHost: host.domain.com\r\nConnection: Close\r\n\r\nHave you attempted to use curl to simulate the monitor connection, so you can see the response?
