David_Rickard's avatar
David_Rickard
Mar 14, 2017
show running vs. list commands
Hi can anyone explain what the difference is between "show running-config" and "list"?
They are both listed in the documentation as valid commands and the output appears very similar, but there's nothing to say why the two commands exist.
Thanks David
  • I believe F5 created command(
    show running-config
    ) based on cisco device. Don't see any history about this..
  • I never used the show running-config, so I did some quick tests:
    [root@LABBIGIP1:Active:Changes Pending] config  tmsh show running-config > show.txt
    [root@LABBIGIP1:Active:Changes Pending] config  tmsh list > list.txt
    [root@LABBIGIP1:Active:Changes Pending] config  ll
    -rw-r--r--.  1 root   root        132912 2017-03-14 13:22 list.txt
    -rw-r--r--.  1 root   root        132912 2017-03-14 13:21 show.txt
    [root@LABBIGIP1:Active:Changes Pending] config  diff list.txt show.txt
    So, both commands are the same. I guess because a lot of people are used to Cisco CLI, F5 just create show running-config as an alias for list command. I am saying that because this command does not follow tmsh rules.
    In tmsh commands, list is for listing the configuration, and show is for showing the object status. The following 2 commands provide different things:
    [root@LABBIGIP1:Active:Changes Pending] config  tmsh list ltm pool pool_http
    ltm pool pool_http {
        members {
            LABServer1:http {
                address 172.16.0.11
                session monitor-enabled
                state up
            LABServer2:http {
                address 172.16.0.12
                state up
            LABServer3:http {
                address 172.16.0.13
                state up
        monitor http
    [root@LABBIGIP1:Active:Changes Pending] config  tmsh show ltm pool pool_http
    Ltm::Pool: pool_http
    Status
      Availability : available
      State        : enabled
      Reason       : The pool is available
      Monitor      : http
      Minimum Active Members : 0
      Current Active Members : 3
           Available Members : 3
           Total Members : 3
              Total Requests : 16
            Current Sessions : 0
    Traffic                                  ServerSide
      Bits In                                     78.3K
      Bits Out                                   109.5K
      Packets In                                     60
      Packets Out                                    45
      Current Connections                             0
      Maximum Connections                             7
      Total Connections                               7
    Connection Queue                               Pool  Pool and members
      Number of connections queued now                0                 0
      Number of connections serviced                  0                 0
      Queue head entry age (ms)                       0                 0
      Maximum queue entry age ever (ms)               0                 0
      Maximum queue entry age recently (ms)           0                 0
      Average queue entry age (ms)                    0                 0
  • List is typically "listing" the configured output in bigip.conf. Show results in statistics logged by datasets in MyDB, & TMM.
    I typically like to do a lot of
    "tmsh show running-config /ltm pool X one-line"
    This is awesome when you want to execute quick clones of a configuration. It also has helped me in the past standardize a lot of REST commands, and efficient scripting for certain application builds in automation attempts. That way I can live life a bit more... haha
