Technical Forum
Sharing data between iRules
Azzeddine_S
Cirrus
Cirrus
Hi all
I am currentely trying to implement two irules assigned to two different virtual servers with different types , the first iRule collect data and insert it in a table, the second iRule needs to access the data stored in the first table and make forwarding desision.
thanks all
2 REPLIES 2
Hello Azzeddine_S.
Here you have an example of using an iRule table
https://community.f5.com/t5/crowdsrc/especial-load-balancing-active-passive-scenario-ii/ta-p/280675
Hope this helps you.
Regards,
Dario.
Azzeddine_S
Cirrus
Cirrus
Thanks a lot @Dario_Garrido
i have found a solution and i will share it once i have time to write/draw somthing nice
