Technical Forum
Several maintenance pages in the same VS
mika
Cirrus
Cirrus
Hello,
I want to use several maintenance pages in the same VS, but when I used the irule that contains several maintenance pages and when two pool are disable(two maintenance pages are activated) maintenance pages doen't work. and when one pool is disable (one maintenance page is activacted) the maintenance page is working.
So my qst is: can we use several maintenance pages in the same VS ?
Best regards,
Malika
1 ACCEPTED SOLUTION
Samir
MVP
MVP
You can configure n number of iRule for maintenance  page but at a time only one page will be displayed.
3 REPLIES 3
Samir
MVP
MVP
thank you for your answer
srir
experts!
how to enable two different maintenance pages within F5 / iRule
I am trying to enable more than one maintenance page on F5 based on the specific condition.
  1. if pool down - maintenance page1 should be displayed
  2. for any unplanned outage - maintenance page2 should be triggered.
any inputs, highly appreciated !
