Technical Forum
Setting up a load balanced SFTP Server using F5 LTM v 11.6.5.2
vinodbhaskaran
Hi ,
I am trying to setup a load balanced SFTP server using F5 LTM v 11.6.5.2. Could anyone please advise any suggestions on how to do this.
I followed the steps as per the article below albiet it saying version 12+ . I did not create the optional login monitor using expect scripts.
https://support.f5.com/csp/article/K24595255
 ssh <My_VS_IP> -vvv
OpenSSH_7.4p1, OpenSSL 1.0.2k-fips 26 Jan 2017
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 58: Applying options for *
debug2: resolving "<My_VS_IP>" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to <My_VS_IP> [<My_VS_IP>] port 22.
debug1: connect to address <My_VS_IP> port 22: Connection refused
Regards
Vinod
2 REPLIES 2
vinodbhaskaran
12:27:23.869567 IP <My_Source_IP>.43960 > <my_VS_IP>3.22: Flags [S], seq 1311613444, win 29200, options [mss 1460,sackOK,TS val 2420492952 ecr 0,nop,wscale 7], length 0 in slot1/tmm0 lis=
12:27:23.869585 IP <my_VS_IP>.22 > <My_Source_IP>.43960: Flags [S.], seq 4082142113, ack 1311613445, win 4380, options [mss 1460,nop,nop,TS val 3334377052 ecr 2420492952,sackOK,eol], length 0 out slot1/tmm0 lis=/Common/<My_VS_NAME>
12:27:23.870783 IP <My_Source_IP>.43960 > <my_VS_IP>.22: Flags [.], ack 1, win 29200, options [nop,nop,TS val 2420492953 ecr 3334377052], length 0 in slot1/tmm0 lis=/Common/<My_VS_NAME>
12:27:23.871085 IP <my_VS_IP>.22 > <My_Source_IP>.43960: Flags [R.], seq 1, ack 1, win 4380, length 0 out slot1/tmm0 lis=/Common/<My_VS_NAME>
vinodbhaskaran
thats the tcpdump output on the F5 LTM
