18-Aug-2020 17:44
Hi guys
I need your help !
script delete after upgrade
I don't know why script is deleted
script located in /var/tmp
thank you
Solved! Go to Solution.
27-Aug-2020 10:49
Hello.
F5 uses LVM to map their partitions.
Only some partitions are shared between all different volumes (upgrade boot locations)
The rest of the partitions are independent for each volume (boot location).
# lvs
LV VG Attr LSize Pool Origin Data% Move Log Cpy%Sync Convert
app.ASWADB.set.1.mysqldb vg-db-sda -wi-ao--- 12.00g
dat.log.1 vg-db-sda -wi-ao--- 500.00m
dat.maint.1 vg-db-sda -wi-a---- 300.00m
dat.share.1 vg-db-sda -wi-ao--- 20.00g
dat.swapvol.1 vg-db-sda -wi-ao--- 1000.00m
set.1._config vg-db-sda -wi-ao--- 3.17g
set.1._usr vg-db-sda -wi-ao--- 3.29g
set.1._var vg-db-sda -wi-ao--- 3.00g
set.1.root vg-db-sda -wi-ao--- 440.00m
set.2._config vg-db-sda -wi-ao--- 3.17g
set.2._usr vg-db-sda -wi-ao--- 3.29g
set.2._var vg-db-sda -wi-ao--- 3.00g
set.2.root vg-db-sda -wi-ao--- 440.00m
As you can see above, there are two sets of var/usr/config/root partitions (1 and 2).
These numbers correspond with the digits used in your volume (HD1.1 and HD1.2).
# tmsh show sys software
Sys::Software Status
Volume Product Version Build Active Status
HD1.1 BIG-IP 12.1.5 0.0.6 yes complete
HD1.2 BIG-IP 12.1.3.4 0.0.2 no complete
So, your lost script should be located in the next partition:
/dev/mapper/vg--db--sda-set.#._var
Where '#' is the number of your previous volume.
Regards,
Dario.
27-Aug-2020 10:49
Hello.
# lvs
Regards,
Dario.
01-Sep-2020 02:12
thank you for shared information
