Technical Forum
SAML SP ACS Post back resulting in a 404
Cirrus
Cirrus
Cirrus
Hello,
I have one application configured to use APM via SAML authentication, the SP & IdP are both running directly on our F5 - this setup is working for many applications only for this one i have problems with the SAML flow.
So only some web ressources from this app are protected, we used here an iRule in order to handle this, when i access one of the protected URIs i will be redirected to our IdP in order to get the authentication (KRB Ticket), this is still working i get a session for it (Allowed state) and see also the correct SP in the reference. But the bost pack from Idp to the SP to the ACS /saml/sp/profile/post/acs is resulting in a 404
Accessing protected web ressource -> www.app1.com/protected No session right now so i will be redirected to Idp -> idp.com/saml/idp/profile/redirectorpost/sso (Post; State 302) Redirect back to SP -> www.app1.com/saml/sp/profile/post/acs (Post; State 404)
Anybody an idea how to solve this or where i can start with the error search?
Thanks,
Christoph
1 ACCEPTED SOLUTION
Cirrus
Cirrus
Cirrus
Finally solved this topic with the help from F5 Support - thank you so much.
The main issue is that not my whole web app is protected through APM as this would have serious performance impacts, therefore we have defined some protected sites. When hitting any of these URIs APM will be enabled, default is disabled.
And in that code we forgot to also have /saml URI enpoint marked as protected site as this is the SAML SP endpoint after IdP Session was created. Now we come up with that iRule, which is working great for our purpose
       # Check the requested HTTP path
       switch -glob [string tolower [HTTP::path]] {
              "/saml/*" -
              "/en/confidential/*" -
              "/de/confidential/*" -
              "/confidential/*" {
                     # Enable APM for these paths
                     ACCESS::enable
              default {
                     # Disable APM for all other paths
                     ACCESS::disable
4 REPLIES 4
PeteWhite
F5 Employee
F5 Employee
When you do the redirect, does the user have a session? The user should present back a session ID in the cookie which ties up the first redirect with the response
Cirrus
Cirrus
Cirrus
So i'll get the IdP Session and after the redirect back to the SP also the session for the SP is starting. In my Access Profile the first element is the "Saml Auth" which is also generating the Session variable, but then it stops and the access profile is not finished and therefore the session on SP side will never finish
In my opinion it's a problem from the webpage in the background, it's a TYPO3 CMS and I think that 404 page is delivery from that website, but i don't know how to workaround that or to avoid such things in the future
Cirrus
Cirrus
Cirrus
Push - Any other ideas?
Cirrus
Cirrus
Cirrus
              "/saml/*" -
              "/confidential/*" {
                     ACCESS::enable
              default {
                     ACCESS::disable
