SAML request signing and digests with SHA256?
THi
Altocumulus
Altocumulus
In 11.5.0 APM (Jan 2014) APM started to support SHA256 for SAML assertions.
424572APM SAML can now operate with other systems using either or both of these groups of algorithms: RSA-SHA256/RSA-SHA512 XML signature algorithms SHA256/SHA512 digest algorithms. It continues to sign its own SAML messages (AuthnRequests and Assertions) using RSA-SHA1.
Does APM still (in June 2016) use only SHA1 for SAML request signing and digests? In the F5 SAML AuthRequests we have http://www.w3.org/2000/09/xmldsigsha1" />
We have a major IdP no longer supporting SHA1, they want SHA256: http://www.w3.org/2001/04/xmlencsha256" />).
Are there plans for the SAML SHA256 signing and digests?
0 REPLIES 0
