Ernesto_M's avatar
Ernesto_M
Nov 17, 2020
Solved
Resolve 2 IPs at the same time, with failover in a 3rd one
In BIG-IP GSLB, I want to resolve a domain, for example, www.example.com, with 2 IPs at the same time (1.1.1.1, 2.2.2.2), and when these 2 IPs are down, resolve with a third IP (3.3.3.3). For example, in a nslookup this is what I want:
> nslookup www.example.com
Servidor: dns.google
Address: 8.8.8.8
Respuesta no autoritativa:
Nombre: www.example.com
Addresses: 1.1.1.1
         2.2.2.2
I achieved something similar using Wide IP, where I created 3 pools (1 per IP), the 2 main IPs are balancing in Round Robin and the 3rd IP is used as Last Resort Pool, the issue is that the 2 main IPs aren’t resolving at the same time, they’re balancing correclty, but no resolving at the same time, only one per nslookup request.
Another test I did was using Return to DNS as main action in pools (with previous Zone Records configuration), here I can resolve both IPs, but failover with 3rd IP doesn’t work.
Do you know what can I do to accomplish this?
  • Hello,
    My understand, in your scenario you can run with a single pool and a fallback IP:
    To get multiple answers, change the "Maximum Answers Returned" on pool properties.
    E.g.
    WideIP: www.my.domain
    Pools:  Pool_A
    Last Resort Pool: None
    Pool_A:
      Properties:
        Maximum Answers Returned: 2
      Members:
        1.1.1.1
        2.2.2.2
        Load Balancing Method:
          Preferred: RR
          Alternate: RR
          Fallback: Fallback IP
        Fallback IP: 3.3.3.3
    If you need to work with a last resort pool setup, you can:
    Pools:  Pool_A
    Last Resort Pool: Pool_B
    Pool_A:
      Members:
        1.1.1.1
        2.2.2.2
        Preferred: RR
        Alternate: RR
        Fallback: None
      Fallback IP: 0.0.0.0
    Pool_B:
      Members:
        3.3.3.3
    I hope this helps.
    Best Regards
  • Hello,
    E.g.
    Pools:  Pool_A
    Pool_A:
      Properties:
      Members:
        1.1.1.1
        2.2.2.2
          Preferred: RR
          Alternate: RR
    Pools:  Pool_A
    Pool_A:
      Members:
        1.1.1.1
        2.2.2.2
        Preferred: RR
        Alternate: RR
        Fallback: None
    Pool_B:
      Members:
        3.3.3.3
    I hope this helps.
    Best Regards
    • Ernesto_M's avatar
      Ernesto_M
      Hello cjunior,
      This worked for me, thank you very much!
