11-Apr-2022 04:54
Hi everybody,
I need to remove the values of a response header. For example:
access-control-allow-headers -----> X-Request-UUID, X-Web-Optimize-Response, X-Web-Client-Id, X-Web-City-Id, X-Web-ClientI
I need to remove "X-Web-City-Id" and keep everything as they are.
I couldn`t find a related iRule.
I would appreciate it if somebody could help me with this.
Best,
Ali
13-Apr-2022 02:16
Hello Asamadyar.
If the header is located in the Response, you could remove it with next iRule.
when HTTP_RESPONSE
HTTP::header remove "X-Web-City-Id"
Take into account that you would need a HTTP profile applied.
14-Apr-2022 00:57 - edited 14-Apr-2022 00:58
Many thanks, @Dario_Garrido
I don`t want to remove the header; I need to remove one value.
header ------------------------------------------- value
x-x-x t1, t2, t3, t4, t5
And I need to remove, for example, "t3" and keep everything intact in the response header.
I think your code will completely remove the header (x-x-x).
19-Apr-2022 10:27 - edited 19-Apr-2022 10:54
Hello Asamadyar.
Try with this code
when HTTP_RESPONSE {
if { [HTTP::header "access-control-allow-headers"] ne "" } {
if { [HTTP::header "access-control-allow-headers"] contains "," }{
set acheaders [split [HTTP::header "access-control-allow-headers"] ","]
set output ""
foreach acheader $acheaders {
if { $output eq "" } {
if { !($acheader contains "X-Web-City-Id") } { set output "$acheader" }
if { !($acheader contains "X-Web-City-Id") } { set output "$output,$acheader" }
#log local0. "INPUT: [HTTP::header "access-control-allow-headers"]"
HTTP::header replace "access-control-allow-headers" $output
#log local0. "OUTPUT: [HTTP::header "access-control-allow-headers"]"
