Redirected too many times.
Ok, I know this has already been answered her in a few different ways but after making changes and testing I am still having iussues I am getting the error xxxxxxxxx.com redirected you too many times
here is the irule
Checks the URI and forces to all lowercase
switch [string tolower [HTTP::host]] {
"zzzzz.zzzzz.com" {
if { [HTTP::path] eq "/"}{
newclient Redirecting
HTTP::redirect ";
return
} } "xxxxxxx.xxxxx.com" {
HTTP::redirect ";
return
} } } No match.
- youssef1
Cumulonimbus
Hi Aaron,
The problem is due to your irule.
in fact you make a condition that says that if you have an uri equal to "/" you redirect the user to the same uri "/". so you get a loop...
you should have some things that looks like this:
when HTTP_REQUEST { Checks the URI and forces to all lowercase switch [string tolower [HTTP::host]] { "zzzzz.zzzzz.com" { if { [HTTP::path] eq "/"}{ newclient Redirecting HTTP::redirect "https://zzzzz.zzzzz.com/NewURI"; return } } "xxxxxxx.xxxxx.com" { if { [HTTP::path] eq "/"}{ newclient Redirecting HTTP::redirect "https://xxxxxxx.xxxxx.com/NewURI"; return } } } }You will be redirect to the new URI in order to not trigged condition again ("/").
Hope it's clear for you. Keep me udpate
Regards,
- youssef1
Cumulonimbus
Hi
But you confirm that you modify my irule. You need to set the uri of the redirection...
What is the goal of your irule ? Redirection on a specific path depending the hostname that's right ?
Regards
