Puneet_73909's avatar
Puneet_73909
Mar 08, 2010
Re-direct on an outgoing URL
We want to be able to set a re-direct on an outgoing URL (Inside to the outside intertnet) on the Load Balancer.
For e.g;
If the outgoing packet has the following URL:
recs.igodigital.com
Redirect that to:
recs-gamma-aws-lb.igodigital.com
Please provide us the solution asap.
Regards,
Puneet Khanna
  • hoolio's avatar
    hoolio
    Hi Puneet,
    Can you clarify when you want LTM to issue a redirect to the URL? Is it on HTTP redirects? Or do you want to send a redirect to the URL when the application sends a specific response code? Or do you want to search for response content that contains recs.igodigital.com and rewrite the references to recs-gamma-aws-lb.igodigital.com?
    For the last case, you can use an iRule like this:
    URL rewrite
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=1167408&ptarget=1167410
    Aaron
